In considering a car to buy is Gen II preferabley for mostly track use, I've a couple questions.
If I am attempting to upgrade the Braking System on a Cast Piston Car with ABS:
What modifications will be required to be made to the Master Cylinder if I consider replacing the rear calipers with a set of front calipers which have much bigger pistons and Swept Area?
I have heard of people using the Front Calipers in back and putting a new set of Brembros up front, but what about ABS cars?
What modifications will be necessary to keep the brake fluid's volumetric pressure intact? or possibley increased?
Thanks for All and Any supporting Answers!
Jay K.
Jay K.
