acrx headers what size is best ?
nismobrown
wales, GB
i want to fit a new set headers on my 97 gts .
i have a 3" corsa cat back.
k and n and smooth tubes.
can anyone tell me if the 1 3/4" acrx headers will be suitable or are the 1 5/8" a better bet ?
i am thinking of fitting the larger diameter in case i want to tune the car more in the future.
thanks!
Glen97
Valley Springs, CA
I have the ACRX headers on my 97. I went with 1 5/8 upper part of header and 1 3/4 lower part the same as the ACRX. Give Todd a call at BBG. Nice power & sound.
BAD BOYZZ GARAGE
Sacramento
thanks!
nismobrown,
You'll be fine both ways on your GTS or RT 10. The 1 5/8" stepped to 1 3/4" merger header work extremely well in the V10's stock configuration with standard modifications ( Roller Rockers 1.7 upgrade, smooth tube & high flow filter intake systems, high flow cat back mufflers, light flywheel, gears and tune ), good to 550 - 600 crank hp. Back pressure, velocity & scavage of this 1 5/8" to 1 3/4" stepped headers is why they respond on this platform.
If your looking specifically at S/C, high compression head & cam N/A packages then going to the 1 3/4" staight through design would be my recommendation with out doubt.
Toddy
N
nismobrown
wales, GB
thanks!
are the measurements ID or OD on these headers ?
will they throw a check engine light ?
do the exhaust ports match up well to both size headers ?
if I fit the 1 3/4 " with the intention of further mods but end up not getting further mods done, will it spoil the way the car drives ?
can i re fit my stock header heat shields ?
can I wrap cats with ceramic bandage to protect sills ?
nismobrown,
Toddy
countourcafe
