any creampuffs running Paxson SC?
Dave T (BADVENM)
Goodland, KS
havent heard anything from my original post so I thought I'd try again. If so, can you provide specifics and whether you upgraded the pistons to take full advantage of the available boost.
Thanks.
Flyviper
So Cal
Re: any creampuffs running Paxton SC?
Stock motor with 5# boost. About 5k miles since blower installed-- no problems. Runs smooth on 91 octane gas in Cal. Tuning is the important thing and that was done by Dan Craigin.
D
Dave T (BADVENM)
Goodland, KS
hardviper, any 1/4 times or power/torque numbers with your setup. we have similar bolt ons. thanks for the info!
2002_Viper_GTS_ACR
Charlotte, North Carolina
Have a tuner set up the fuel system correctly (read more $$$), because the kit out of the box is a POS. I am on record here as being one of the creampuffs busted because of paxtons DIY kit. Be VERY carefull !! ITs not a DIY !
Jon
D
Dave T (BADVENM)
Goodland, KS
i was going to have woodhouse install it or a Roe while it was up there for a Unichip fix. The car is back with me, lessening the temptation. as for the unichip issues i had per previous posts, i'll take the car out over the next few days to see how she runs.
thanks for the info, I remember reading your posts about your problems.
HARDVIPER
Temecula Ca.
If I remember right without finding the files, 635 crank, 564hp, 545 t.
