Back-up lights out
ViperJoe
Virginia
Both are out, not the fuse, haven't checked bulbs (couldn't imagine both out, but I'll check).
What's next, reverse switch on the tranny?
Is there any adjustment at the shifter when it's in "R" or switch adjustment?
Anything else anyone can recommend checking, replacing, or adjusting?
Ulysses
San Diego, CA. USA
When the switch is bad, both lights go out. All the switch does is gate the current, (Flow/no-Flow). You can test the switch by bypassing it, if the bulbs light up, then the switch is bad.
countourcafe
