Boost Gauge
SapphireGTS
Columbus Ohio
Can you do a boost gauge with Roes supercharger? If so, how?
Do you tap into the tube going to the Vec2?
Keith
jcaspar1
Sacramento, CA
From what Sean said in previous posts, the gauge should read 5 psi at all rpms. He didn't seem to see the point in it with his style of blower if I recall.
SapphireGTS
Columbus Ohio
I guess that makes sense and I was kind of thinking that.
They look so cool though. After all the hard work I want to leave my hood off so people will know:)
thanks for the reply
Keith
fuelman
Lake Mary, Florida USA
I have an autometer which matches the factory white on the gauges. The bezel had to be painted black as it comes silver. Macedo placed it on the steering column, it looks stock, however I don't look at it much when my spine is being straightened by the boost.
SapphireGTS
Columbus Ohio
Fuelman... Does it pretty much stay the same (like 5 lbs) if you have a 5 lb pulley?) as mentioned above.
proracer1
Michigan
some one pm me an e mail address i have a photo i want to put on the site of my gauge panel
Larry Macedo
Sanford, FL
John,
I actually had the bezels polished to match the factory gauge bezels. It's the little things that count ;)
Yellow Fever
San Diego , CA
I've seen pictures of Jeff's Gauge installation..It looks awesome :eek: !
I'm going to post some pics of his set up later this week. His whole car is SICK ! One of the sweetest GTS's on the road.
Cheers
Jeff
Larry Macedo
Sanford, FL
Autometer sells a pressure transducer that will attach to the schrader valve (fuel pressure adapter) on the Roe fuel rail.
Nadine UK GTS
Bath, Somerset, UK
Hi Larry, can you give me a contact for "Autometer" please? And, also any part number for the pressure transducer that will attach to the schrader valve, as I'd like to fit a fuel pressure gauge to here. Thanks, from overseas!
Larry Macedo
Sanford, FL
Hello Nadine,
The Autometer 2-1/16" Phantom Fuel Pressure Gauge, Part #5763, includes the transducer.
SapphireGTS
Columbus Ohio
Larry. I am probably doing this. Whats the difference betweem
ATM-5763 and ATM-5712. They both have the same description . . . Does one have a transducer and the other doesnt? I noticed one is about 3 times the $$$ :)
Keith
treynor
Redwood City, CA
I believe you will find that even with a roots blower the boost will not be constant. Obviously it will be less when you are not at WOT; similarly, it will change depending on the volumetric efficiency of the engine at various RPMs. Whether that's interesting to you or not is a different question.
Of course, just having a boost gauge with a positive reading in a Viper is interesting enough for most of us :)
Nadine UK GTS
Bath, Somerset, UK
Thanks Larry and Sapphire for the info.
I totally agree with Ben for what he says about a boost gauge.
Here's mine! It was a small pressure gauge from a shop compressor (thanks Joel) that I fitted quick for fun so I could 'watch' as well as feel the boost! It shows no vacuum, and trouble is with most boost gauges they are for upto often 30 psi so the standard Roe 5 psi sees the needle wavering on the low end scale of the gauge, oh well guess the boost could always be increased! (Note UK export speedo only goes to 180 mph! How will I ever know if I make 200 mph?)
DChan415
San Francisco, CA
The $189 autometer fuel gauges are stepper motor gauges. The cheaper ones are mechanical and have to be mounted outside the passenger compartment.
EmmmaHot
