eliems
For the last couple of weeks there have been infrequent times when I go to brake and the pedal goes farther (sometimes much farther) toward the floor before it applies.
The fluid was up but dirty so I had it flushed and changed. Pads are 35% all around and no leaks. No air in the system either.
Still feeling this with the pedal though. It will stay pumped for most of a drive and then suprises me again.
Master cylindar is letting fluid by? (IF so do you guys replace or rebuild the Master)?
Booster loses pressure? (What is that like to fix)?
Thanks.
Thanks.
