Burnt low beam - 400 miles from home
boplaw
I assume it is a dealer only part ?
Thanks in advance.
Cape Coral, FL
yes, dealer only part.
And realistically, once you see the price of the part, you will probably want to look into just buying a used headlight assembly...
Cape Coral, FL
you can find them online. They are HID D1s bulbs. Try this link, hope it helps..
HID Xenon D1S/D1R Replacement Bulbs
If you go this route, either make damn sure that it is an exact match, down to the manufacturer and part number, or replace them in pairs. Otherwise, you chance having two different color headlights...
(and even if it is exactly the same, they will still be a tad different- the color temp changes as the bulbs age.)
B
boplaw
Thanks for the info/link.
Yes Zen, we had fun until about 3 am and then.....
