Closed Loop
Closed-loop is fully warmed up and running in a range from above idle to between 3 and 4000 rpm. WOT is usually open-loop.
The blinky codes are only available on cars thru about '98, I think. They just tell you what fault code has been set in memory.
C O D Y
Vancouver, WA
"The blinky codes are only available on cars thru about '98."
The blinking codes work on cars '97 and older.
