Comp Coupe Measurments...
VOI9 ASP
These may be helpful for those of you that are also looking into purchasing a trailer for your new ride...
Distance from center of tire to center of tire on rear wheels is 63.5o inches. (This is helpful if you plan on using the recessed in the floor E Track option for securing your car inside the trailer ILO of D Rings)
The widest point of the Comp Coupe is 77.50 inches
The distance from the ground to the bottom of the car door in the open position is 12.50 inches (This is helpful if you plan on adding the side door option so that you can open the door to get out over the trailers inside wheel well. The floor height will need to be high enough to allow for your door to open when parked inside the trailer)
The distance from the ground to the bottom of the splitter is 3.50 inches. (This is necessary to know as far as ground clearence at the front of the car and the length of the ramp used in entering your trailer.)
Thanks to Viper Race HQ for this info.
V
VOI9 ASP
I think I am going with the 22' Pace V Nose. They gave me a much better price than the 24' Featherlite and included more options. They ended up being about the same weight, even though the 24' is aluminum. The delivery time was shorter also. I have heard good about both trailers.
FrankBarba
have any of you checked out the Gold Rush Trailers?
or even performance trailers in California?
countourcafe
