Coolant temp gauge fault?
Nadine UK GTS
Bath, Somerset, UK
Just wondering before I pull my dash out if anyone has had experience of a faulty coolant gauge? My '97 has had the gremlins strike again! I'd run him real slow about a mile, waiting for him to come up to temp, and then suddenly his gauge shot upto max read, past the red!!!! I checked him out but he wasn't even up to normal operating temp, no leaks, no loose wires etc. As the sensor (in the head) sends to the PCM and I had no check engine lamp or fan operation, I'm thinking test the gauge for fault first, or the loom for a short? The gauge still reads max if from cold I put the ign on! All the more reason to install an oil temp sensor too now!
DChan415
San Francisco, CA
Before you pull the dash, unplug the one wire coolant temp sender. If the gauge reads 0 with it unplugged, and reads max with it plugged in, its shorted internally. Otherwise, if the wiring between the sender and the gauge is shorted, it will read max also.
DEVILDOG
VCA Member North TX
VENOMVILLE, TEXAS, USA
Maybe the guage got crossed up and is measuring your tire temps after your world famous burnouts! :D Above sounds like good info to try versus pulling the dash. Good luck.
