Cylinders Bore
D
diamond head
I tried searching other posts on the maximum bore size, but still can not find anything. Does anyone know:dunno:
Slithr
Friendswood Texas
Call Greg Good in Houston (713 290 1103), he should be able to help you with your question (highly respected straight shooter) :2tu:
99 R/T 10
Enterprise, AL USA
Stock bore is 4.030. Generally .060 is max, but Greg Good or any other tuner should know for sure. Always stay with the minimum amount of metal removal as possible. If you can get away with .010 over, do it instead of going to max. Pistons can be custom made in just about any size.
D
diamond head
I had 4 cylinders damaged when the top of the pistons cracked. It looks like I need to go .030 over.
jmillsUT28
East Tn
And if you need any help Mike (99 R/T 10) will be willing to drive to your house and help you!! lol
