Defroster/Air Conditioning FAN not working
jimbalayajag
LYNNWOOD, WASHINGTON
Here I am again......my 2006 SRT-10 Coupe has no blower behind the dash...so no air coming out of my dash, defroster, or floor....
I can turn the fan up and down and nothing happens.......I went and bought a 40a fuse and it didnt work
so I need some good advice...this is obviously a FAN issue, so please help me
VPRPWRD
Orwigsburg, PA
I had a low mileage 04 Viper in the shop that had a bad blower motor. Could also be a resistor but usually the high speed will still work when the resistor is bad.
Bandit3
Atlanta
Jim, same thing happened to my 06. Water from cowl drains into rubber vent hose going to fan motor. Rusts fan motor shaft. Very easy to replace the motor, especially if your skinny, which I'm not. Think i bought mine from dealer. Check autozone and Napa, some parts for our cars are interchangeable ( cheaper). Some here might have a permanent fix. Good luck, John
Dan Cragin
LA, CA
Yes its either the blower resistor, fan motor or both.
