Where is the diagnostic port located on a 95 R/T?? On my GTS's it is located on the driver side kicker panel. I'm helping a friend scan his car and could not find it on his 95.
It's on the harness that goes into the PCM, but it is a different style plug then what the 96+ cars (and ODBII scan tools) use. Should be simple enough to make an adapter, but I haven't gotten around to it. Per the Service Maunal, it WILL give you the P#### codes (more granularity that the codes from the on-off-on-off-on method).
