Does anyone know of an aftermarket rear view mirror kit for the GTS?
ACR Joe
Newtown, PA
The message is ambiguous. Side view or rear view mirror(s)? I wouldn't change anything on the outside of the car. Inside - tint the backlight.
Matt M PA
Langhorne, PA USA
As far as an outside mirror replacement, I have never seen any. However bear in mind that they are Dodge Stealth mirrors (Mitsu 3000GT)..maybe a aftermarket import company makes one? That said, the mirrors are large because the car gets wider as it goes back..it's the only way to see well. The inside auto dim mirrors are simple to install. I put one in my Bronco years ago. Mine has the compass, outside temp...but no dimming as they were not out then. It hangs from the existing mirror button on the glass, and you just run some wires.
Jay Herbert
Sunnyvale, CA
I'm putting powered mirrors on my '94 RT/10, (they are off a Stealth). One thing that I noticed was the base for the passenger mirror was a little taller, maybe a half inch. This little bit makes a big difference, specially if you have a side curtain car.
A company in Germany named Getra made some wild side mirrors, They looked like F-40 mirrors with two supports. http://www.getra-online.de I'll put a picture at http://www.viperclub.org/images/Getra_04.jpg for you to look at. I'm not putting the image here, cause it is a large file.
