caj98GTS
Tomorrow is tear down day! In order to fix the blown head gasket problem I am going to tear down the top end of motor so I can get the heads off and get them over to Greg Good and let him work his magic on them before putting new gaskets on!
I obviously need to drain the cooling system. The radiator drain plug appears to be a simple hex/allen wrench type plug. However, the block drain plugs have me a little confused. First of all, I am assuming that they are the two, fairly flat plugs located on the flat/horizontal surface of the block right behind the exhaust manifold merger prior to the v-band clamp???? If these are the right plugs, they look like they are a square drive type bolt. Is that square drive set up for a 1/4 or 3/8 in socket drive? If not, what size tool/square drive device do I use to get these things out?
Thanks for the help.
