ENGINE DUST
FLX109
Massachusetts
How do I clean this engine of road dust? Wiping it does not work to good, I am A little worried about engine cleaners or spraying it with a hose, any info would be helful
thanks
FLX109
BADVENOM
port washington, n.y. usa
Light degreaser with a rags works..If you want you can take a small spray bottle with some water and lightly spray areas to help with the job if you want to be meticulous..
ViperJoe
Virginia
I use my central vacuum with a couple of different soft brush attachments. works great for road dust, grit, and little tiny stones that mysteriously find there way to areas around the engine and front top of the side sills.
GaryA
USA
I spray it down with a hose and wipe it down with a soapy cloth and then rinse with the hose. Never had a problem yet and the engine compartment stays clean.
Jeff Torrey
Plaistow, NH USA
I hose mine down. Only time I had a problem was when I used a cleaner (citrus base). Got a check engine light and the headlamp fogged up for a week.
When things dried out everthing was fine.
