Need a southern NH Viper mechanic recommendation
cnpnh11
New Hampshire
Hey all - I've had my 2000 RT10 for about a year and put roughly 1k miles on it during that time. I've recently noticed that the transmission is having issues. I cannot get the car into gear on most days unless I have the key "on", but the engine off. Once it's in gear, I can hold the clutch, start the car, and begin using it. After a little driving, it warms up and becomes a little smoother (shifting), but still not great. From research, it seems like it's possibly a slave cylinder issue, but I'm not certain. Even with the clutch pushed, if I take my foot of the brake, it begins slowly rolling in the direction (forward or backward) of the gear I have it in, so maybe it's something else and clutch-related? Regardless, I'm relatively new to Viper ownership and don't have a specific person around my immediate area that I can rely on for transmission work and hoping to not get hosed due to ignorance. I've been a lifelong European car owner (BMW/MB), and have much familiarity with those cars, and I've done plenty of work on them, but not this one. Given the appreciation for this car, I don't want to make any matters worse in tinkering, as I usually do on my other cars. Any recommendations are greatly appreciated as I begin looking for someone to rely on here. Thanks!
Do you get any grinding going into gears especially when cold?
Does kind of sound like the clutch isn't full disengaging.
Have you tried to bleed the Clutch?
cnpnh11
cnpnh11
New Hampshire
I'm assuming, since the car slightly moves when the brake is released (clutch pedal fully down), that it isn't fully disengaging - right? I haven't tried bleeding the clutch. Is this a relatively straightforward process?
cnpnh11
cnpnh11
New Hampshire
Oh cool - thanks! Since you're in MA, do you have a mechanic you rely on, or do you do your own work?
