Viper Mechanic (Alignment) Central Ohio
emjohn43
Ohio
As the title states....looking for any recommendations / knowledge for an alignment in Columbus Ohio area.
I've read enough posts to know it's not really a straightforward alignment, and having just replaced the bushings...holy cow the car drives better...would like the alignment done right.
Willing to drive a bit, but would like to stay in state.
Thx!
With all fresh bushings, you can start with all 8 cam pairs pointed straight up in their slots. Unless the car has been bent, that should get you a pretty benign caster/camber setting and all you need to do is set the toe to spec. Once you've found a good shop, they can fine-tune to your driving preference. There are 2 Ohio shops I know of - Complete Performance Motorsports and Viper Works.
E
emjohn43
Ohio
Thanks guys! I'll be giving both a call in the upcoming couple weeks. Much appreciated!
