Engine Indicator?
dubai daffodil
The ACR seems to be enjoying life in the desert apart from the temperatures of late.
However, on the dash panel, an indicator light of an engine comes on when started and stays on. Everything seems to be fine with the car otherwise.
Any ideas? We don't have a manual as yet so not quite sure what the indicator is trying to say!
Omaha NE.
If it is an 08' it could be that the vari cam is sticking a little. How many miles on her? also is it stock or has there been "stuff" added.
mike & juli
Upstate NY
If I haven't already...CONGRATULATIONS on your 2001 ACR...! Pics when you can post them, unless you already have! I may have missed any of your previous posts, sorry bout dat!
WELCOME and hope you get things figured out with your car...I KNOW Mark from Woodhouse can help you out! ~juli
Omaha NE.
There is a good chance that you have either an 02 sensor that is tired or maybe an Evap system leak. Either way you will need to find a way to get the codes to diagnose the issue. Lights that ore on solid are generally all emission related.
xeng yang
