Error Code 152 ????
Dixter
Plano, Texas USA
Had a warning light on the dash and my decoder says its error code 152...
Anyone know what component is sending that code out...
Thanx
I think its a high voltage error, but not sure what part would send that out..
plumcrazy
ALL OVER
it says::
O2 sensor circuit high voltage (bank2 sensor 1)
now what that means i have no idea...lol
GOOD LUCK
Jack B
NE Ohio
The passenger side front O2 sensor is out of range. The difference in oxygen content (across the sensor) from the exhaust side to open air generates an output voltage via a galvanic reaction. That voltage will oscillate between 1.3V and .5 V for a narrow band sensor. The PCM monitors the amplitude and the frequency, once it detects what it believes is a deviation, it will set the code. That deviation could be a bad sensor, contaminated gas or a bad connection.
ZOOMBI U
Newmarket, Ontario
H02S1 shorted to voltage Sensor1, Bank2
Monitor run conditions (Enable Criteria)
1) Engine running for at least 2 minutes.
2) Coolant temperature over 175 degrees.
Why did this code set?
1) The task manager detected an 02 sensor voltage of greater than 1 volt for more
than 2.5 seconds.
What should you look for?
1) Simply unplug the sensor connector while monitoring the voltage under the above
conditions. Voltage should return to bias (apprx .5 volts) if it does, replace
sensor. If it stays high then you will have either a PCM or harness problem.
