Extreme Horsepower Internals
Cape Coral, FL
As seen in the previous post that I had to cancel, these parts are for an EXTREME application. I now can release these parts to recoop some costs, but I cannot let the block go for some time, so I will just split them up as they are not yet assembled. These were designed to be Drop-In to a low-mile 2004-2006 SRT-10 that has just had the bores honed. (may fit 2003 also, unsure off the top of my head if they use the same crank journal diameter and width) Rotating assembly WILL need to be balanced! Suitable for NA or Forced induction, either pull out or add CC's to head chamber volume to raise or lower compression away from stock. Recomended for use with Cometic gaskets in .045 thickness no matter the application- this will allow an EFFECTIVE quench of .045, as these pistons run zero deck at TDC.(note, if no head changes occur, and you use .045 gaskets, this will increase compression on an engine with these internals to roughly 9.8:1, as OEM gaskets are .053)
These are BRAND NEW...9 of them havent even been inside a block! Rated for 2200 Horsepower @ 6500 RPM. Here are all the specs;
Rods:
-Carillo H-Beam ($3800.00)
-7/16 SPS-CARR Bolts (The strongest!)
-.990 Full Floating Wrist Pins, .200 wall w/ Diamond Hard Coating ($550)
-Forced Wrist Pin Oiling
-Federal Mogul Race Bearings (Coated) ($200)
Pistons: (Designed for 4.031 bore)
-Custom CP Blower/Tubro Pistons ($2700.00)
-Every single option; Anti Detonation, Acccumulator Groove, Lateral Gas Ports, etc)
-Full Swain Tech Coating Package, domes and skirts ($600)
-dual Spiral-locks
-Stock Compression, tight quench (dome -cc's=compression height increase +cc's)
-Reverse chamber profile
-Gas-Nitride top rings
-Napier Second
-SS Oil Pack
I have over $8000.00 into these parts, looking for 7500.00 OBO. Viper D gets first dibs, as he responded first about the block. I will be out of town until Sunday- Please leave any questions here or e-mail them and I will answer when I return!
I apologize in advance for any mistakes, I wrote this quickly as I am on my way out the door! Stock Comparison shown...as pathetic as it is next to that work of art!
Cape Coral, FL
Yes, they were pull-outs from my Mamba. I have sold 1, but I have 9 left. On a side note, I will have 10 BRAND NEW assemblies out of a 2006 block in a few weeks too.
Cape Coral, FL
Any offers out there? I have not yet yet heard from Viper D, so they are still currently available.
VIPER D
dutchess county, ny
hey Dan
thanks for the firts dibbs.
But for now I am looking for a fast swap/ short block or a winter project with Internal parts. Also I don't know if I want to stay with the stock compression I want to go lower and stroke it as well
thanks anyways.
vd..
