Yikes ! 1993 was such a 'wierd' year, with over 200 chages occuring between Vin 001 and 1055.........
The Borg-Warner (now Tremec) T-56 internal parts should be available from any local tranny shop that works on BW Vette transmissions.
The problem with the fans is that "superceded" part numbers not only replace but sometimes upgrade the part. Your dual-fan 93 has a 12" left, and a 11" right. The same motor for both sides.
What does not fit? The larger shroud is left side. Hmmm.
If you E-me your part number, I can see if that matches what PartsRack would have sold you......
JonB~~~~:<~
JonB~~~~:<~
