front blinker change.
Darth Menace
Edmonton, Alberta
hey, i was wondering if there is a relatively simple way to change the front blinker without taking too much apart. Where do we get access?
Fatboy 18
Surrey, United Kingdom
You mean the orange front side marker / Indicator?
Thought we had just been down this road? Depending on what side of the car you are working on, turn the front wheel so that the front of the wheel is turning in towards the inner wheel arch.
You will then notice a large rubber **** in the front of the wheel arch.
Remove the rubber ****, and put your hand through the hole and feel the back of the Side marker lamp.
Twist the bulb holder to release and pull the wire with bulb holder back through the ********* so that you can replace the bulb.
Replace Bulb, re-fit bulb holder in back of lense and replace Rubber ****.
Then do the same again to the other side of the car.
Jance GTS
Oklahoma City, Oklahoma
Once you remove the 3 wing nuts to the backside of the housing, the light can be changed out easily. Most likely 10-15 minutes to do both sides once you take everything apart or possibly 5 minutes. Dead simple. No worries.
