Front End Cover Help Please...
SRTaj10
SF Bay Area, USA
So I bought myself a bra also known as a front end cover for my SRT-10. It is a Mopar producat and I picked it up from my local dealer. There is one big problem though...there are no instructions in the box. For teh most part it is pretty straight forward but I am really puzzled with one step. I am goign to explain this the best I can...If you are looking at the car from the direct front the bottom of the bra has like an elastic cord that goes through loops alont the bottom side of the bra. This elastic cord has hooks on either end of it...My question is where do these hooks hook on to? The cord basically hold the bottom side of the bra in place so it is crucial I hook these hooks correctly. Thanks again and help please!!!
AviP
New Canaan, CT
If I remember correctly, that goes into the back of the bumper. Just reach in under the bottom and past the scrape lip. If the product has changed since 7 years ago, then I suggest you just experiment with it. I threw out that ****** product 5 years ago when my paint shop guy showed me the damage it caused in the long term. Now, I don't wear a bra and love it. :D
GR8_ASP
Avi is correct. I have only tried the bra once. I was a little concerned that it did not fit tight enough and could flap in the wind. My intent was to use on trips or the track.
knuk
I use mine only for the highway and the track - comes off immediately after use as it will mess the paint up if you plan to leave it on. Also fits very tight which is good as that prevents any little pebbles etc. getting under the bra and scratching the paint. I have no concern at all with it "flapping" around as the fit is so good - no problem at the track.
I will send a picture to your email address (please let me know if you don't get it) with regards to your question - where you see the pencil pointing to is where the hooks go! If you want I can fax you a copy of the instructions.
