Front Spring rubbing shock??
R
RTED
Guest
Right front spring on Gen I rubbing shock. Any ideas how to adjust or correct problem. Concerned that the spring will wear a hole through the shock.
Thanks,
RTED
Tom F&L GoR
Wappingers Falls
There's really no "adjustment" to make. Either the shock is bent or the spring itself is sagging and has bent oddly. You can't even rotate the spring; the bottom end of the spring has to sit in a spiral seat on the shock body and so only sits in one orientation. Time to take it out and look at what's causing it. If you need a spring, let me know.
RedEnuf93
Lancaster, PA
Take the wheel off and see what the problem is.
I would not drive an inch at this point. It is not "typical" that the spring touches the shock absorber.
BarryLB
