Gen 2 rt/10 subwoofer
SuperSaiks
Hey Guys
Who's replaced the subwoofer in their car with a direct replacement 6.5 inch sub. What brand did you guys replace it with.... and was it a easy fit..
Also what does it take to hook up a new deck using the existing wires....
Randy
Earth?
JL Audio model "6W0", and it even seems to sound better. I replaced mine about 6 weeks ago. Only place I could find the speaker for less than $100 (before tax/shipping) was online at www.woofersetc.com - the direct URL would be: http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=2073
I originally order one from "etronics.com", then they said they were out of stock and tried to sell an "equivalent", which wasn't even a subwoofer.
Only problem with this woofersetc.com is they don't tell you which type of the 6W0 you are getting - the 4 ohm (6W0-4) or 8 ohm (6W0-8) impedance model. The stock Gen II RT center speaker is a 6 ohm, btw. The one I ended up with is a 4 ohm, and it seems to be fine. Oh, when you get it, you have to remove the two cool rubber things attached to it (they slip right off; one on the front rim, the other around the magnet) or the speaker won't fit into the mounting location, and I drilled new holes to mount it, as the stock holes made the "JL" logo off by 45 degrees (no big deal, but it looks silly/cockeyed if you don't).
SuperSaiks
Depth wise did you have any problems like having a hardtime puting the stock grill back on...
Randy
Earth?
You're right, its a very close fit - thats why you have to remove the cool rubber thing that comes on the magnet, or you can't get the speaker in. But, it did fit, and, although I thought the upper edge of the magnet was touching the back wall, yet I've heard no buzzing or anything similar to indicate it actually is touching.
No members online now.
GetiiingcloswrZB2
