Gen III Motor in a Gen II??
AviP
New Canaan, CT
It should. It's basically the same motor bored from 8.0 to 8.3L. Hopefully the motor mounts are in the same place. Has anyone done a visual check in terms of the mounts, pulleys, etc?
VIPER52USA
How much does the engine it's self cost? And where would you buy one? DC?
tommygun
According to some experts, the intake manifold is too tall and will not clear the hood. Look at how low the motor sits in the engine bay on the srt-10.
ViperJoe
Virginia
There's one on Ebay right now out of a wrecked SRT Ram.
LOL!!!!
"Dang it, the salesman said this har truck was one dem Viper trucks"
"I thunk I could haul a load-o-stone and handle dem twisty roads with ease at 80 mile 'nour"
BIGBADCJ
Monroe,LA
hell just take your hood off and sell it to cover some cost. looks more bad ass without the hood anyway.
ShadowFox
Guys which engine is bigger: the Gen 2 or the Gen 3? Physically speaking not performance wise. I wonder what it will look like if you drop a Gen 3 engine on the GTS. Will it have more room on the engine bay to add more goodies?
What about if you take out both Engines Gen 2 and Gen 3 and highly mod both, which engine would give the most HP?
Viper4Christ
USA
A gen 3 would fit fine as far as height wise SVS uses a Gen 3 intake set up for their GTS TT RS car, as far as mounting I think you might run into some trouble there other then that you should be fine :usa:
Cape Coral, FL
The Gen-3 engine should fit fine, height wise as pointed out above. I think the biggest issue to overcome will be fusing the gen-3 sensor system with the Gen-2 engine controller. Secondly, the Oil Pan on the Gen-3 may pose a problem, as it sticks a few inches off the side of the engine on the passenger side... clearance to the frame rail me be an issue.
oldvenom
