help me
Crompton
Alberta Canada
K here it is.My car sometimes starts slow like the starter is going or it's not getting fuel.If it is to do with the furl system it would explain the 1/4 tank drop on my gas guage when ever i slow down.The other odd thing is every now and then when starting or turning off my car my wipers turn on.So yeah wire problems anyone have to battle this befor?
Shane
99 R/T 10
Enterprise, AL USA
You got some gremlins for sure. The Gen I's are known to have fuel pressure bleeddown problems. If you cycle the key 3-4 times THEN try to start it up, it should fire right away if it is a fuel pressure bleed down problem.
Does it seem like a weak batt.? On the wipers moving when trying to start the car, I would call Chuck Tator, he ma have some insight. 914-763-3136.
C
Crompton
Alberta Canada
battery is full power thats why it's odd.I will call him if my mech can't figure it out.thanks alot
dave6666
Try pulling the fuse or relay to the wipers, assuming it has one or both. If it still does it the problem is not related to the wiper controls, and is after the fuse box.
Dan Cragin
LA, CA
Do you have an aftermarket stereo? I have seem problems with the wiring that cause the wipers to come on. Could also be the wiper switch or control module.
viper2002
