help-plug wire order
VIPR GTS
xenia ohio usa
OK guys, I blew it, putting on my new MSD wires, passenger
side, took a phone call from an old friend and bam, I'm lost. Opened my manual to page 8I-2, the page is gone. Does anybody have the plug wire routing for a 2002 GTS or can you send me
a copy of the pages I am missing. The drivers side is done and
the back two cylinders of the passenger side, which plug to which coil post.
Thank for any help I get.
Tony
ACR Larry
RPV CA USA
Back of Viper
COIL
bottom 8 10 2 4 6
top --- 9 5 3 7 1
10 E 9
-8 N 7
-6 G 5
-4 I 3
-2 N 1
---E
Front of Viper
The wire holders should hold the wires in this order:
| 2 ---4 | Engine | 3 ---1|
| 6 8 10 | ------ | 9 7 5..|
* The coil numbers where stamped on the coil pack, but barely visible and hard to read.
V
VIPR GTS
xenia ohio usa
Larry, once again you prove the fact that this board has a great base of members that are both helpful and knowledgeable. The wires are on correctly and the motor sounds great. Thank you for your rapid response.
Tony
jpolen21
