Hood adjustment .
Garry Fuller
Henderson, Nevada
2002 GTS, hood on pass. side has a gap of 1/2 to 5/8 in. where it meets the nose on front side. Dr. side is normal. Is there an adjustment to lower pass side of hood down.
This might be a dumb question, but did you press down fairly firmly on both sides of the hood when closing it? On my mom's 94 there is a latch on either side of the hood at the front and sometimes one side doesn't latch fully when closing it which can cause a gap like that. I usually press down right around the headlight on both sides to make sure it's fully latched.
KyViper
off to get a Beer
Here is a Pic of my 97 and 01 hoods showing gaps on both sides.
My research indicates that this is pretty typical of a Gen 2 hood fitment where one side gap may be larger than other side.
I did not and would recommend to others not to mess with adjusting their hoods for these typical gaps.
Maybe a Pic of yours might be helpful to see if it is worse than normal.
Ky
ViperRed
Bahrain
Unfortunately, I feel that these gaps are caused by deformity of the hood over time.
A good fiber glass fabricator may be able to fix the issue for you.
Garry Fuller
Garry Fuller
Henderson, Nevada
Thanks everyone. Hood is latched tight. Adjusted light up so it wouldn't look so large. Going to check other adjustment.
countourcafe
