hose replacement
yellowviper
I want to replace the rubber hoses on my 2001 rt/10 with steel braided ones. I want to do the coolant but not certain if I should do brake lines also. Your opinion. Do you know where I may get them? thanks. Jack
Chuck 98 RT/10
tampa, fl USA
I'd do the brake lines. Plenty of vendors with the brake lines - Roe, etc. Personally, I'd pass on steel braided coolant hoses. The only gain is visual, all else is negative IMO. Weight, heat, wear against any other lines or wires possibly resting against them.
Viperbat
