V
vegasviper
Guest
I have done this many times on small block chevys, is it a similar procedure for the viper engine. Any tricks i should know about
2 hrs to get them off on the ROE. 2.5 on the non-ROE.
Jack B - A second ago there was a $1000 bet you were offering??? What happened to that wager offer?
<g>
JD
You guys are getting out of control![]()
JDAWG, get to the dyno yet?![]()
JD, Don't you answer your phone no mo![]()
Rich -
If you'd quit breaking off bolts in the heads, it would take a lot less time! How many do I have to extract now?!?
in/lb and ft/lb are different!
JD
J Dawg:
I see you have the car running good, what was causing the high speed miss?
