How To Repair 1/4" Hole in Fascia??
MAMBA
Winter Springs, Florida
How To Repair 1/4\" Hole in Fascia??
Does anyone know if the front fascia material is ABS or RTM and if so what is the correct method to repair (4) 1/4" drilled holes (front license plate bracket mounting)? Will fiberglass reinforced filler work or should I try to get a "flex filler" made for specifically for plastic parts? Also to fill a deep scratch can I use a regular automotive glazing putty or should it also be a flexible filler?
Hopefully some of you have gone done this road already.
JDR
Eureka, CA USA
Re: How To Repair 1/4
Use TPO filler - In the Yellow Pages, look for an autobody/autopaint supply store - most will sell to the general public too.
