Install Complete - Gen IV Seats into a Gen II
Jack B
NE Ohio
In an earlier post there was a lot of discussion on whether Gen IV seats would fit into a Gen II. I permanently installed the drivers seat today. Here are the details. Note, all the dimensions are for a 97 GTS and the seats were a 2008-2009.
Benefits and Issues
1. The seat can be installed so that the Gen IV seat bottom height is identical to the Gen II oem height, therefore, if your Gen II seat allows a helmet, so will the Gen IV seat when mounted properly.
2. The Gen IV oem track is used and maintains the adjustability. It is actually better than the Gen II, the adjusting increments are smaller, therefore, you can find the sweet spot easier.
3. The adjusting lever is a full bar in the front, therefore, easier to use. The adjustment lever for the seat back is on the side, also easier to use, although a little hard to access.
4. The support and looks of the Gen IV seat are superior.
Install:
1. The seat comes out easy, however you have to position it correctly. The bolts/nuts are both 13 MM. The front bolts are best removed with a ratcheting box wrench. The back nuts are easy to reach with ratchet and extension, just move the entire seat forward and the seat back forward also. Once you have the seat loose move the track until you have directly it under the seat, you do not want the track/brackets projecting out in the front or back. Next, push the seat entire seat forward and move the seat-back to the rear, go past 90 degrees, then, rotate the top of the seat toward the outside, it should come right out. It is probably a good idea to tape a piece of cardboard over the top of the sill kick plate.
2. Once the seat is out you have to remove the four brackets on the corners. The front brackets are held by a bolt and two seam welds. The rear brackets are held by two bolts and two seam welds. Remove the bolts and take a hand held cutoff tool/grinder with a thin cutoff wheel. The welds are not deep, groove them away from the track, then, use a chisel between the track and bracket to pop them off.
3. The Gen II floor studs in the rear are 13" apart. The Gen IV track center line is 13.5". The new adapters are simple, I made mine from 3/16" X 1-1/2" steel bar. A bench top cutoff wheel works real well for cutting them to size. Merely use the old bracket as a template for the position of the three holes (two in track/ one for floor) in the rear adapters. The front adapters will only have one hole/bolt into the track and one for the floor.
Here is the key, the right rear bracket should be mounted to the centerline of the track, however, you want the hole for the floor stud to be 1/4" off center to the right of the track. This pushes the seat to the left by 1/4", that is the sweet spot so that the track functions, it is tight and that was the key to making it work. Once you mount the right rear bracket, then, mount the left rear bracket. The next trick is to make the two holes used to mount the adapter to the track oversize, this allows you offset the bracket so the outer hole (for the floor) can be moved to the inside of the centerline - keep in mine the track centerline is 13.5" and the studs in the floor are are 13.0".
Put the seat back in the car, push the seat forward on the track. This exposes the rear adapters. Drop the adapters over the studs and screw both nuts on a couple of threads so the seat is loose, but, in position.
4. The front adapters are next. Cut the two front adapters at 4.5" long. There is only one bolt holding the adapter into the track. Since the seat front is loose, merely lift it up and and fasten the adapter to the track. Drop the seat and line up the adapter to the center of the floor hole. I took a bolt and cut the head off, ground the top to a point, then, threaded it into the floor hole while holding the front of the seat up. Just drop the seat down and the pointed head of the bolt will mark the adapter. Take the adapter off and drill the final hole when the the pointed bolt marked the adapter. Do the same to the second front adapter and you should be done.
View From Outside
View of Both Gen II and Gen IV Seat
Top View of Seat Recline Handle
Front Seat End with One OEM Bracket Removed
Rear Seat End With One OEM Bracket Removed - cutoff tool in background
Front and Rear OEM Brackets
Right Front Adapter
Left Front Adapter
Left Rear Adapter - Note how it angles into the middle, this is because the Gen II floor studs are 13" to centers and the Gen IV track is 13.5". The red bracket on the right is the roll bar base plate.
Right rear adapter - it is critical that this adapter has the floor stud bolt hole 1/4" to the right of the track center-line. Tighten the bolts on this adapter first. Proceed to the left rear adapter, locate that stud bolt hole 13" from the right side stud bolt hole.
Gen IV seat with Gen IV OEM right rear bracket - compare this with the picture above for a before/after view.
J
Jack B
NE Ohio
I pulled out the passenger side seat today, the space between the tunnel and the outer rail is actually 1/4"wider, therefore, it should easily fit. I measured the floor bolt holes (front) they were on 13" centers (left to right) just like the driver's side. The rears were 13-1/8", the driver's side is 13". Those are studs. I also weighed the seats:
Gen II: 30 lb
Gen IV: 46 lb, 42 lbs when misc hardware is removed.
Fatboy 18
Surrey, United Kingdom
Have to say those seats look huge in that cockpit! If you don't mind me asking, How tall are you? Can you get the seat fully back?
Can you still get the side bar in from the roll bar? Looks great in red.
J
Jack B
NE Ohio
I am six ft and a 43-44 chest, as I said you do not lose any headroom when installed as denoted. The seats look bigger in the picture than they are, it is just they are the closest to the camera. I could never get the oem seat all the way back after I installed the roll bar, however, when it is full back now I cannot push the clutch all the way in, I have to move the seat forward to operate the car. I have never used the side bar. I will say this the SRT seats are tight, the bolsters are big and they hold you in, for me (6 ft) that is good, but, I think the seat inself would be uncomfortable for a person that is broad or large in general
mattdillon
Duck Dynasty Back Yard
They do look like it, I guess it just looks like they wrap around you more & the sides look a couple of inches closer to the steering wheel? Something like that? I've been looking at some & always wondered if they would fit but something just doesn't look right but I'm sure they're definitely more comfortable! Either way, Thanks for sharing this Jack!
