Installing After Market Exhaust Advice Needed
mayo_pasco
bakersfield
I am installing after market exhaust and noticed that on the passenger side the exhaust comes in contact with the heat insulating material. Is this going to be a problem and I should attempt at getting a layer of air between the exhaust and the material or is it nothing to worry about?
GR8_ASP
I don't think it is an issue.
When you installed the exhaust did you ensure that the sides were oriented properly? The right and left side are not the same length as the engine is not centered exactly.
M
mayo_pasco
bakersfield
Thanks for the reply I did see they are not equally centered. After a night of sleep I managed to bend the metal pins a bit to get it straighter so now I have a working Roe high flow cat + B&B muffler system and S&B air filter sounds by far better than original :D
Nieves108
