invisicord install for valentine1
vinny2
atlanta
anyone hook theirs up w/this? can you tell me where to put the pins, inside the mirror? instructions don't list Viper install specs.
thanks
V
vinny2
atlanta
no way to do it so you don't have to manually turn it on and off?
Nader
New York
Where did you get the cord? Do you know if they make one for escorts?
johnk
Laplata, Maryland
vinny2, I'm not aware of a switched source at the mirror in my 06, not sure about any other Vipers. Since mine is pretty much a toy just turning it off is not an issue for me personally, might be different if it were my daily driver. The alternative would be to run 12' of wire from a switched source under the dash, up through the a piller, above the headliner, and to the mirror. Good luck.
V
vinny2
atlanta
mine is a weekender only as well, so not a big deal. Thanks for the info.
Hiss
Kentucky
I have not, as of yet, installed the invisicord. Presently I have the V1 wired to the mirror plug. My V1 goes off about 30 sec to a Min after I get out of the Viper and when I open the door the V1 comes on. Ive had it wired for about 5 months and I forget exactly what pins I went to. When I get my car back from DLM I am going to check this out.
Grunt
The Lone Star State
So your's follows the pattern of the lights on the mirror.
They all might do that. I was just paranoid that my battery would run down cause I didn't have time to set and watch.
I will set and watch now.
johnk
Laplata, Maryland
Come to think of it, you guys are probably right. That circuit has a delay built in for the interior lights. I'll go test mine in a minute and let you know.
Added: Yep, the V1 automatically shuts down a minute or 2 after car is off and doors are shut. Good to go.....
