Viper Fuel Rails Kit
Applications: 1994-2002 Viper V10 - All
New F&B low profile fuel rails capable of supporting over 1300hp! Designed for most top feed injectors, these fuel rails have four 3/8 NPT inlets/outlets for maximum flexibility in running your fuel system. Pictured is a dual feed, dual return with large pressure dampers for 90+lb injectors. Our cable relocation kit allows you to run your throttle cable under the fuel rails for a clean, trouble free installation. All hardware, cable brackets, and cams are provided in the kit. The fuel rails are dipbrazed, clear anodized 6061-T6 aluminum for multi-fuel use. F&B rails will fit under the rear cowling, and provide a super trick, factory look! You can see them in the Pennzoil synthetic oil ads in the June and July 2005 issues of Hotrod magazine!
