Spinning up a heavy wheel takes more power than spinning up a light wheel.
I've seen the hp numbers but I can't remember them.
Slowing down a heavy wheel takes more brake power than slowing a light wheel.
Any race car will improve with a lighter wheel. That's a fact. And that includes drag racing.
Street driveability is the only downside.
MWAAHAHA!!!!Joe, we disagree on the other thread, but we agree on this one.
1 for 1 not too shabby.
The only downside in terms of street drivability is that the car will be more prone to dieing at idle while cold, and would affect only low speed drivability.
Tis was told to me by a motorcycle builder/racer (750cc), but I have not experienced it. I also am in the car and always let it warm up for a few minutes, give a little gas, so that may be why. And I don't drive 'low'.
Clutch,pressure plate,and flywheel spin in circle(creating centrifugal force).
Lighter aluminum flywheel will have less weight,less force,easier to engage/disengage.
My calculations are already in other threads dealing with this.
EQUIVALENT WEIGHT=0.5x(flywheel weight)x[(flywheel radius x gear ratio x final drive ratio)/(tire radius])above 2(that's squared)
In essence, in first gear you shave off hundreds of pounds of equivalent weight. It does decrease as you shift up, but you're still shaving off equivalent weight in each gear.
