Lower Dash Panel Removal?
JKVIPER
Millstone Township, New Jersey
I am in the final stages of installing a cruise cotrol system for my 06 coupe.
Can anyone explain how to remove the driver side lower dash(knee blocker) panel? I need to remove this to expose a 12volt Acessory wire as well as mount the cruise control transmitter.
Thanks,
Joel
Billy The Kidd
Peekskill, NY
you can use the power pedal toggle for your power source. just remove the two screws on the bottom and pop it off. The top has clips, make sure to pull it straight out!!! Good luck!
Racer Robbie
Guilford, CT-USA
Use a test light with a ground clip attached to any metal ground. The wire that lights up the test light is the hot wire.
Robbie
Johndirt
