Michelin Cup Tires
Chuck 98 RT/10
tampa, fl USA
I did a search but couldn't find if the Michelin Cup tires came in 17 inch. Also can't find them on Tire Rack's site.
Does the Cup tire come in 17 inch?
Jack B
NE Ohio
Like Russ said, you will be happy with the Kumho's (Estra 700's). You have to have them shaved for the track, you can run them unshaved on autocross, however, the surface may get chunked.
A hint, the Estras are available in a 3.35 x 17, however, the next size down is either a 2.75 0r 2.85. You can go to the Vito Racer in a 3.15 x 17 for the front. It is a different compound, however, both tires show no roll at all even at low pressure.
Ray W
Fort Lauderdale,FL USA
I don't know if they are still available but they do exist.
When I bought mine I can't remember if it was because of inventory reduction or elimination.
