Motul RBF 600 brake fluid?
F
Fiorano
Vienna, VA
What brake fluid could I use for the street that would work well and won't boil at the track? I boiled the stock fluid at VIR.
slaughterj
I use Motul all the time, for brake and clutch fluid. But IIRC, if you are going to use performance fluids like Motul, you don't want them in your car for 18 months - so if you don't put on much mileage, and expect the fluid to last for the typical stated mileage, then Motul probably isn't for you. (However, I get ~18k a year, so I change it in plenty of time.)
95Viper
Phoenix
Motul is dot4 (they make a dot5 but you don't want that) and has outstanding boiling points. It will over time absorb less moisture than other fluids but I'm like slaughterj and replace mine every two years. At only $10, it's perfect. The only other option is to use the Castrol for the track at about $100 a change.
