My Tips On Installing Corsa Exhaust...
2002graphiteviper
Minneapolis, Minnesota, USA
I have been meaning to post this for a couple weeks - figured maybe this could help some people that will be installing in the near future (Jamie!)...
1.) Thanks JonB - order one day - got the next - called another VCA member over for a couple hours of fun. Corsa system...
2.) When removing the sill - those strange little caps - be careful. If you bend them - when you snap them back in when complete - they'll look chewed. Also, the remaining screw - right under the door hinge - not sure how someone can screw that back in with 1/2 inch clearance. So, ended up saving the screw - and just putting the cap over the hole.
3.) When removing the mufflers - it says that you can "tap" the old system towards the rear - and the pipes will come apart. NOT! Now, my car was less that a month old - and zero rust on any of the bolts - and we struggled with "tapping" that exhaust off... Sledge hammer was more like it - pretty much had to do some damage to the old muffler to get it off. Gerald can posts the pics that he has of that old muffler... Removing that muffler was by far the most difficult and time consuming part.
4.) Careful when installing - some of the pipes we installed had stickers on them that stated "drivers side" - and that was incorrect... Just takes about 30 seconds to realize the bends don't quite match for the sensor - so don't rely on the stickers...
5.) When tightening the clamps - start it up - look for leaks. Almost every one of the brackets we installed needed to be cranked on again due to leaks. And that is another thing - if you are torking them on - be careful - I snapped one of the bolts right off.
6.) Before you tighten any of the back hangers - or brackets - measure the tip outlets - and make sure that those have the same amount of space on each side - they tend to pull all the way to one side - and you don't want to figure that out after you've cranked all the brackets on...
7.) Make sure to clean those sills out as long as you have them off - I bet there were 3,000 pebbles in mine...! Not sure how they all get in there - but I could have made a small sandbox for the kid!
8.) This should have probably been mentioned in an earlier step - but when you have the exhaust off - with just the CATs hanging - make sure to fire it up and let the neighbors know what you're working on...! My neighbors love me!!!!!
So, just my two cents - if it was not for the muffler issues - I am guessing that two people could have gotten the entire job done in a couple hours... And although I notice that people say that one person could do it - I think that would be a pain in the a$$ - especially pulling the sills off, etc... I am sure it could be done - but to save you some time creating new swear words - invite someone else over to help...
Very pleased with the system - fairly inexpensive - and definately a change in the cars personality... The way it should come out of the factory...!
Kurt 97 GTS
Dallas, TX
Recently did the same thing with my Borla exhaust. Had a few tips in response to your numbers:
#2. Use a rachet that has a special handle that bends upwards to about a 45 angle. Works like a charm!!
#3. Use a rubber end malet!! Works like a charm
ruckdr
Renton, WA USA
Just some additional thoughts and comments:
I did mine by myself on jack stands (the car that is), and on my back (me). A couple of days before the system arrived, I removed the side sills and soaked the joints with liquid wrench penetrating stuff. Pipes came apart easily.
2.) ........ Also, the remaining screw - right under the door hinge - not sure how someone can screw that back in with 1/2 inch clearance. So, ended up saving the screw - and just putting the cap over the hole.
<HR></BLOCKQUOTE>
Use some Scotch tape to secure the screw to the socket, a short extension, start by hand, and tighten using pliers to turn the extension.
<HR></BLOCKQUOTE>
Rubber Hammer
<HR></BLOCKQUOTE>
Mine had NO stickers, however, this was not a 1000 piece puzzle (only 5 pieces)
<HR></BLOCKQUOTE>
YES, proper alignment.
<HR></BLOCKQUOTE>
As I said above, I did do it myself, and the hardest thing was getting the muffler section up and through the rear facia, lying on my back, trying to get the right angle. It was REALLY a tight fit, perhaps because my car is a '96 RT/10 and the rear area MIGHT be a little different from newer years??
<HR></BLOCKQUOTE>
GLEN, I agree completely ........
Later,
Kurt 97 GTS
Dallas, TX
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by KFMSLM:
Kurt,
How do you like the Borla? Is it too loud for a RT?
<HR></BLOCKQUOTE>
I really like the Borla. Very nice deep and throaty sound. I had the Borla cat-back on my 94 RT and loved the sound. I do think it is louder than the Crosa, but it's not a daily driver and is not an issue for me. You may be able to find a good used system, which will sound the same and then you will have more money for headers, high-flow cats, roller rockers.........
2002graphiteviper
Ruckdr - yeah, I agree completely... Getting the new exhaust and tips thru the back opening took some time - so probably the same size on newer and older models.
In regards to the rubber hammer - yup, great idea, I think the best solution would be rubber hammer and then also like the other person did - spray the pipes in advance - and let 'er soak.
The only reason I didn't was because I only had a couple hundred miles on the car... And just thought some people with earlier models would do a little more prep - and then the pipes would probably break apart pretty easily...
tbone96
