Need help with fuses.
HawkeyeViper
Clear Lake, IA USA
I believe the fuse for my cigar lighter has blown ie my Valentine One won't work (but works in my other vehicles). I took of the panel to get at the fuses and on the back of the panel it lists all of the fuses and their postions except the cigar lighter fuse.
Yes I am a mechanical *******!!! Any help would be appreciated!
luc
Paso Robles CA
If I remember correctly, the cigar lighter fuse is inside the fuse box underneath the hood,by the master cylinder.
Luc.
00GTS
HP
Little Rock,AR,USA
Mine is fuse #7 25amp - but this circuit also controls some of your lights
so I doubt that the fuse is your problem - pop the panel off that holds the
lighter, and check the positive wire that plugs onto the back of the lighter -
it seems to come loose easily.
