New Iridium-Enhanced .6 mm Fine-Wire & Platinum Projected Tip Spark Plugs
Knight Viper
Harford county MD
My denso iridiums are 13 ea... i set up a dealer acct to get them for 10 ea... but even still, throwing out 10 like i did yesterday hurt. in the gut. ouch.
Joseph, tossing $100 away every time you try a different tune or want a new set of plugs does hurt. I was thinking I wanted to try a couple of different sets when I spend the day on the dyno but I think I will go with just the stock heat range and one colder per Sean's instructions.
R
Racer Robbie
Guilford, CT-USA
Joseph,
Do your Denso plugs have the required projected tip? Last year i was not able to find a Denso iridium plug with a projected tip.
Robbie
R
Racer Robbie
Guilford, CT-USA
Thank you for your response Joseph. Stryker heads do not require projected tip spark plug though the factory OEM heads do require them. To the best of my knowledge Denso does not make a projected tip iridium spark plug.
Robbie
Joseph Dell
Atlanta, GA 30338
Actually, stock heads don't require a projected tip plug either.
Robbie
No members online now.
Bora472
