Nitrous and other stuff
nemo
Ok so I have searched here and have looked in the god forsaken alley. Not one place has weather you can just slap on a low power nitrous kit, like 75 - 150 shot on the car. I don't really want to do this to mine how ever a friend does. If a person were to put a kit on the car would the tourque management system shut you down, would it throw a code, would the motor detonate, would the plugs fry. All questions I have not been able to find for the Gen 4. Also is there any thing that a guy could do to pull a little extra power ex. on most cars you can pull the throttle body off and port it a bit on the in and out as long as you stay away from the blades good for 1 or 2 hp and you can put a spacer on most cars, waller out the manafolds a bit just little things that are cost effective ie free. thx in advance Nemo
N
nemo
Does any one know if the mopar pcm will allow you to run that nitrous as its supposed to be a learning pcm?
Ideal983
