NJ / PA area. NEED HELP finding a place to install high-flow cats. HELP!!!
TAXIMAN1
NJ
Ok, so it sounds like a simple task. However, last time I took a car to the local Meineke (My 2002 Z06). I ended up needing my rocker panls re-painted.(idiots dragged the car down the entire lift).
So, does anyone know a place in the NJ / PA area that I could trust to do this job. WITHOUT risking damage to my car?
Also, I have not purchased the cats yet. Im torn between the Roe Racing and Randon Tech Cats, any input on which would be better for my application? My car is 100% stock (besides Corsa Exhaust). And I intend ot keep it that way. My main objective in purchasing these cats. Is to cool down my side sills.
NOTE: UNFORTUNEATLY, Im 3 hours away from Tators, Or else I would not even be making this post. I am willing to travel up to an hour or so..
RedEnuf93
Lancaster, PA
I got mine done at "Old Gold", in Hershey, PA. They actually specialize on old 1955-57 Chevy's.
These guys are top notch. I'm not sure how far it's from you, but everything was perfect, icluding the side exhaust centering and I'm anal as hell...
plumcrazy
ALL OVER
Re: NJ / PA area. NEED HELP finding a place to install high-flow cats. HELP
just got my ro ovals installed by tator and i KNOW its done right and love the sound.
3 hours is close enough for me to go to tators.
Mighty GTS
Bucks County, PA
When i did mine, I removed the flex pipe at the header flange and took the flex pipe, RT HF cat, and the first
section of my corsa and marked them with reference lines and alignment arrows. All the shop had to do was weld
on the dotted line... I picked up the welded pipe section
and brought it home and installed. If your reference marks
are accurate, the job is completely bolt on.
All assembly/dis-assembly is done by you so nobody can
screw up your car. 40.00 bucks out the door for the welding at a muffler shop in bucks county PA.
Drmcar
wilm. de usa
Heffner's Performance in Glen Burnie MD is par excellence . Where are you in NJ?
RPHJR
Drmcar: Im in South NJ (about 25 minutes fron the Del. Memorial Bridge). Heffners may work.
Mighty: That is an option as well. May consider it. I have access to a lift as well..
RedEnuf: Thanks, Hershey is within reason for me as well...
Thanks guys, for the quick replies.
T
TAXIMAN1
NJ
After doing mapquest. Im about the same distance from tators, as all the others listed above..
So, at this point. I think I will either take the ride to Tators. Or attempt to remove the system myself, and have the local guys weld...
Thanks for the replies...
Jerome Sparich
T-man, where exactly are you at here in N.J.?
2BADD 4U
N.E. Pennsylvania
I am 3 1/2 hrs from the Wizard and he is the only one to work on my Viper. Take it there...you won't be disapointed!!! If you can get an appointment!
Dave :2tu:
T
TAXIMAN1
NJ
Im in Delran 08075 (about 25min. outside Philly).
Bonkers
DelaWhere? USA
You equal distance to the best two Viper mechanics on the east coast - Heffs and Tators. I'm not sure if Buhlers does this kind of work but they're the closest club sponcer vender to you.
