Parts
q8_viper
Kuwait
Hello,
I’m new to the viper club and I’m worry about the parts if I buy GEN 2 Is it very hard to find parts for example power steering pump ,Weatherstrip and Steering Gear for GEN 2 . I think the factory closed and they don’t care about GEN 2 also the car is old
yevgenievich
Brazos Valley, TX
Most things if rebuildable have to be rebuilt. Other things only available used. My solstice is in similar situation with body and interior parts. I bought gen 2 over the newer gen because I like the gen2 better.(compared to gen3)
I think you have a bit of an advantage in that the earlier gens used a lot of shared parts between Dodge products. I know for instance the alarm module in my mom's 94 is the same one out of a minivan. Granted those cars aren't any newer, but it at least means you might have a larger volume to pick from.
ViperRed
Bahrain
Yes that's correct. Gen1 and Gen2 vipers shared parts with other Chrysler or dodge models.
When my power steering pump failed, I repaired it locally, and got the new belt from a Jeep Cherokee Limited
Mechanical parts are easy to get and available.
Body parts and plastic interior parts are difficult.
kssssnake
I replaced a rear wheel bearing, which by the way was not fun, It's used on Dakotas.
littlecaars
Mohnton, pa.
Years ago I had to repair/replace a map light in the headliner of my 2000 GTS. Of course the only way to replace the map light was to buy the whole harness and headliner for $1200. But the harness from X2 Builders for 50 bucks and four hours later with a sixpack the job was done.
