PCM ?
Cape Coral, FL
lol, in case anyone wants to hear what this is about, i'll post it right here:
"""Technically, yes it will... though I cannot take any responsibility for it if you use it in a car other than intended (Like anything from anywhere). the 05-06 cars have dual knock sensors which your car does not have. plugging this PCM into your car will leave the inputs open, and should not pop a code, and will not affect timing as knock sensors output voltage based on knock. 0 Volts=no change, and an open circuit will yield 0 volts."""
And in case you need to know how I know this- I have an 04, with an 06 powertrain, and have run both 04's and 06's on 04 and 06 PCM's. Hell... I just moved an 06 around yesterday with an 04 PCM, and tested an 04 with an 06 PCM a few weeks back as well.
(Jon- he wants advice from elsewhere because I was the one selling the spare PCM on eBay)
miwr
