Pillar pod?
Andrew2KRT10
New York, where else?
I want a dual pillar pod to hold two guages. Anyone know where to get one? I thought I heard something about one from a mustang working out?
Thanks,
Andrew
v10kingsnake
south jersey
andrew the mustang pod does work but you need to heat it with a blowdryer or heat gun to make it fit top notch, or elsi you will have slight gaps where it meets the windshiel pillar. i have seen several done correct and a little trial and error and it works perfect. CHEAP TOO!!!-v10
1MEANSNAKE
Prince Frederick Maryland, On the Chesapeake Bay
We are test fitting our Dual Pod A-pillars Tuesday on Mark Coopers GTS and will have them soon after when they are run in production numbers :)
No more wishing or waiting, they will soon be here. Each gauge pod houses 2 1/16" gauges :2tu:
We have our Gen II single Column Gauge Pods in stock and under a group buy at $45 shipped right now, here is a pic and ordering information:
Make your purchase here! :cool:
Billet Gauge Surround Rings are also available!
