pinning the ati damper
easy stuff but it takes TIME to do it RIGHT.
i pre drilled the dampner on a drill press and used those holes as a guide for the drilling on the crank. they were perfect when it was done.
when i took off the original dampner which was drilled and pinned wit hthe roe kit, the holes were very crooked and the pins were barely in the crank. it woulda spun off.
vipzilla
CAPE COD MASS.
ive been wondering about that im pulling off my stock crank pulley wich is pinned with roe pins do they come out when pulinthe damper
Cape Coral, FL
If you want, we can EDM keyways into your ATI damper so you can use dual 1/4" keyways. [your crank must be keyed as well of course]
Cape Coral, FL
thats just it dan how do i key the crank shaft without taking it out?????
That would require a special fixture, surely something that you (or I for that matter) don't have laying around. It could certainly be made, but by far the easiest way is to just remove the crankshaft.
if the car was in south florida, DLM can do the keying IN the car. and affordably too.....
Cape Coral, FL
Are you 100% sure that it is a TRUE square key? I have my doubts, since I am dealing with another car right now which went through DLM, and it indeed still uses ROUND pins/keys, which we all know can be done in the car.
just spoke to doug sat night about it. its a square key and while the damper is IN the car....
vipzilla
CAPE COD MASS.
update !!! i pulled factory damper off and the roe pin came out with it ..the drill hole it left behind was perfect on the crank we used a dremill and worked it a little and now the key fits PERFECT
Vip08
